Async Motor Driver not working for pymongo based functions
I am trying to create an async version of my MongoDB functions using the Motor driver for MongoDB.
Platform settings:
python (sys.version): 3.10.0 | packaged by conda-forge | (default, Nov 10 2021, 13:20:59) [MSC v.1916 64 bit (AMD64)]
MotorVersion: 3.0.0.0
TornadoVersion: 6.1
OperatingSystem: Windows 10, 64-bit . Intel Core-17
pymongo.version : 4.1.1
pymongo.has_c(): True
The following is my code for the normal synchronous version of the tasks.
## Import Libraries
import pymongo
from pymongo import MongoClient,ReturnDocument
from pymongo.errors import ConnectionFailure, AutoReconnect, BulkWriteError, OperationFailure
import pandas as pd
import time
import credentials
credentials_mongodb = credentials.mongodb
user_id = credentials_mongodb["username"]
password = credentials_mongodb["password"]
domain = credentials_mongodb["domain"]
database = credentials_mongodb["db"]
CLIENT_URI = "mongodb+srv://{}:{}@{}/admin?retryWrites=true&w=majority".format(user_id, password, domain)
def MongoDB_Connection(client_uri : str = CLIENT_URI) -> dict:
    Makes a connection to the MongoDB Cluster and returns success or exception handling (error) messages.
    ## Reference: https://www.programcreek.com/python/example/94224/pymongo.errors
    Parameters
    client_url  : str, default = CLIENT_URI stored in MongoWorks.py
                  Client URL to connect to the MongoDB cluster.
    Returns
    dict        : {Success or Failure message}
    client = MongoClient(client_uri)
    try:
        client.admin.command('ismaster') # The ismaster command is cheap and does not require auth.
        # print("Connecting to MongoCluster at %s - Successful" % (domain))
        return client
    except (AutoReconnect, ConnectionFailure) as e:
        error_message = e + ": Server not available"
        print(error_message)
        return e
def MongoDB_Collection_Write(insert_method : str, collection_name : str, docs_to_insert, db: str = database) -> str:
    Writes documents to a MongoDB Collection.
    Parameters
    insert_method   : str, {"insert_one", "insert_many"}
                      MongoDB write method selection key inserting one document or multiple documents.
    collection_name : str, name of the collection in MongoDB
    docs_to_insert  : a single dict or list of dicts,
                      Documents to insert into a MongoDB collection in list of dicts format
    db              : str, name of the database in MongoDB
    Returns
    messages        : dict, {doc_iD : Success/Failure message}
                      Success or Failure message with documents insertion ID
    client = MongoDB_Connection()
    db = client[db]
    collection = db[collection_name]
    if insert_method == "insert_one":
        try:
            result = collection.insert_one(docs_to_insert).inserted_id
            message = "{} - Document Inserted successfully into `{}` collection".format(result, collection_name)
            print(message)
            return {result : message}
        except Exception as e:
            message = "An Exception occured when inserting a document into `{}` Collection. ".format(collection_name)
            print(message, e)
            return e
    if insert_method == "insert_many":
        try:
            result = collection.insert_many(docs_to_insert,ordered=False)
            inserted_ids = result.inserted_ids
            message = {"DocsInsertionSuccess - {} documents inserted into {}".format(len(inserted_ids), collection_name)}
            print(message)
            return message
        except (Exception,BulkWriteError, OperationFailure) as e:
            if Exception:
                error_message = e
            else:
                error_message = e.details['writeErrors']
            print("Error Message:", error_message)
            return error_message
def MongoDB_Collection_Clear(collection:str, db:str = database) -> pd.DataFrame:
    Deltes all documents in a MongoDB collection.
    Parameters
    collection  : str, name of the collection in MongoDB
    Returns
    msg         : success or failure message
    # Connect to MongoDB
    db = client[db]
    cursor = db[collection]
    try:
        cursor.delete_many({})
        message = "All Documents deleted in Collection - {}".format(collection)
        print(message)
        return message
        message = "An exception has occurred when trying to Clear Collection - `{}`.\t {}".format(collection, e)
        print(message)
        return e
def MongoDB_UpdateCollection_AccountInfo(collection_name:str = "AccountInfoDemo", new_data = None) -> str:
    Updates the `AccountInfoDemo` collection in MongoDB.
    Parameters
    collection_name : str, default = "AccountInfo",
                      Name of the collection in MongoDB
    new_data        : dict, new data to update the collection
    Returns
    Object_ID : str,
                Returns a success message with the object ID
    db = client[database]
    ## MongoDB Creates Collections Automatically no need to check if it exists but for logging may be needed
    if collection_name not in db.list_collection_names():
        print("Creating `{}` collection for the first time".format(collection_name))
        collection = db[collection_name] ## Creates collection for the first time
        operation_result = MongoDB_Collection_Write(insert_method = "insert_one", collection_name = collection_name, docs_to_insert = account_info_sample)
    else:
        try:
            result = collection.update_one({},{'$set': new_data}, upsert=False).acknowledged
            message = "Update Acknowledged:{} - `Balance`, `Equity`, `Profit` successfully updated in `{}` collection".format(result, collection_name)
            print(message)
            return message
            message = "An Exception occured when updating a document into `{}` Collection. ".format(collection_name)
            print(message, e)
            return e
def MongoDB_UpdateCollection_CPH(collection_name:str = "CPHDemo", doc : dict = None, rewrite :bool = False) -> dict:
    Updates the `CPH_Demo` collection in MongoDB.
    Parameters
    collection_name : str, default = "CPH_Demo",
    doc             : dict,
                      a document in dict format to be inserted into a MongoDB collection.
    rewrite        : bool,
                      If True recreate the collection and insert closed positions history from scratch,
                      If False insert the passed document into the collection
    Returns
    operation_result : dict,
                       Returns a dictionary with the object ID(s) and a success or failure message
    closed_positions_history = pd.read_csv("ClosedPositionsHistory.csv")
    cursor = collection.find()
    results = list(cursor)
    if ((len(results) == 0) or (rewrite == True)):  # Checking if the MongoDB Collection (cursor) is empty
        if rewrite:
            MongoDB_Collection_Clear(collection_name)
            message = f"MongoDB Collection {collection_name} - Cleared for ReWrite"
            print(message)
        else:
            message = f"MongoDB Collection - {collection_name} Empty"
            print(message)
        ## Insert entire history of closed positions into the empty collection
        operation_result = MongoDB_Collection_Write(insert_method = "insert_many", collection_name = collection_name, docs_to_insert = closed_positions_history.to_dict('records'))
        return operation_result
    elif doc != None:
        try:
            position_id = doc["position_id"]
            result = collection.find_one_and_update({"position_id": position_id},{'$set':doc}, return_document=ReturnDocument.AFTER, upsert=True)
            message = "Document Inserted successfully into `{}` collection. \nResult: \t{}".format(collection_name,result)
            print(message)
            return message
            print(message, '\n' ,e)
            return e
account_info_sample = {'balance': 27133.2, 'currency': 'USD', 'equity': 27133.2, 'leverage': 25, 'limit_orders': 200,
                        'login': 123456789, 'name': 'John Smith', 'profit': 0.0, 'server': 'Broker-Demo'}
account_info_new_data = { 'balance': 50000.0,  'equity': 49000.0, 'profit': 777.77}
cph_new_data = {'ClosePrice': 2029.90,'CloseTime': '2022-05-14 21:25:16',
                             'OpenPrice': 2024.86,'OpenTime': '2022-05-14 21:24:03',
                             'commission': 0.0, 'fee': 0.0, 'position_id': 221234567, 'profit': 3.0, 'sl': 0.0,
                             'swap': 0.0, 'symbol': 'ETHUSD', 'tp': 0.0, 'type': 'BUY', 'volume': 1.0}
def seq_mongo_tasks():
    MongoDB_UpdateCollection_AccountInfo(new_data = account_info_new_data)
    MongoDB_UpdateCollection_CPH(doc = cph_new_data)
    return None
## CODE EXPERIMENTS
## SYNCHRONOUS TASKS DEMO
st = time.time()
seq_mongo_tasks()
et = time.time()
# get the execution time
elapsed_time = et - st
print('Execution time:', elapsed_time, 'seconds')
The above code executes successfully and updates the mongoDB collections on Atlast cloud.
(tradebot) D:\AlgoBot>python MongoDemo.py
Update Acknowledged:True - `Balance`, `Equity`, `Profit` successfully updated in `AccountInfoDemo` collection
MongoDB Collection - CPHDemo Empty
{'DocsInsertionSuccess - 11 documents inserted into CPHDemo'}
Execution time: 1.6709 seconds
I also made an attempt in making the asynchronous version of the above code using the Motor Driver along withasync and await python operations. But it is not working as expected. Please find the code below for the async version:
## Import Libraries
import pymongo
import pandas as pd
import time
import credentials
import asyncio
from motor.motor_asyncio import AsyncIOMotorClient
from tornado.ioloop import IOLoop
    Parameters
    Returns
    client = AsyncIOMotorClient(client_uri)
    try:
        return client
        return e
async def MongoDB_Collection_Write(insert_method : str, collection_name : str, docs_to_insert, db: str = database) -> str:
    Writes documents to a MongoDB Collection asynchronously.
    Parameters
    Returns
    db = client[db]
        try:
            result = await collection.insert_one(docs_to_insert).inserted_id
            print(message)
            print(message, e)
            return e
        try:
            result = await collection.insert_many(docs_to_insert,ordered=False)
            print(message)
            return message
            if Exception:
                error_message = e
            else:
    Parameters
    Returns
    db = client[db]
    try:
        print(message)
        return message
        print(message)
        return e
async def MongoDB_UpdateCollection_AccountInfo(collection_name:str = "AccountInfoDemo", new_data = None) -> str:
    Parameters
    Returns
    Object_ID : str,
    else:
        try:
            result = await collection.update_one({},{'$set': new_data}, upsert=False).acknowledged
            print(message)
            return message
            print(message, e)
            return e
async def MongoDB_UpdateCollection_CPH(collection_name:str = "CPHDemo", doc : dict = None, rewrite :bool = False) -> dict:
    Parameters
    doc             : dict,
    rewrite        : bool,
    Returns
        if rewrite:
            print(message)
        else:
            print(message)
        operation_result = await MongoDB_Collection_Write(insert_method = "insert_many", collection_name = collection_name, docs_to_insert = closed_positions_history.to_dict('records'))
    elif doc != None:
        try:
            result = await collection.find_one_and_update({"position_id": position_id},{'$set':doc}, return_document=ReturnDocument.AFTER, upsert=True)
            print(message)
            return message
            return e
def async_mongo_tasks():
    pass
## CODE EXPERIMENTS
## ASYNCHRONOUS TASKS DEMO
st = time.time()
# result = IOLoop.current().run_sync(async_mongo_tasks)
loop = asyncio.get_event_loop()
loop.run_until_complete(asyncio.ensure_future(async_mongo_tasks()))
et = time.time()
The above async code runs with some RunTimeWarnings but I dont see the updates in my MongoDB Cloud Atlas Collections.
D:\AlgoBot\MongoDemo.py:213: RuntimeWarning: coroutine 'MongoDB_UpdateCollection_AccountInfo' was never awaited
RuntimeWarning: Enable tracemalloc to get the object allocation traceback
D:\AlgoBot\MongoDemo.py:214: RuntimeWarning: coroutine 'MongoDB_UpdateCollection_CPH' was never awaited
Execution time: 0.01097 seconds
The final application will have some several thousand rows of voluminous data to deal with for the MongoDB_UpdateCollection_CPH function and thus I would like to know if there will be any signficant execution time benefits when using the motor driver in my case. Any help to help me fix my async version of the code would also be greatly appreciated. :pray:
Attached is the sample dataset for MongoDB_UpdateCollection_CPH function:
ClosedPositionsHistory.csv (1.4 KB)
Thanks and Regards,
Dilip
