trying to implement client side field level encryption with free mongodb atlas cluster, completed the part of generating data key id.
Then while trying to do insert encrypted doc facing problem, the code is working till connecting to reg client and after that having trouble to connect to secureClient
question 1 : do we need to install mongocryptd for atlas as well
question 2: am doing something wrong with extraOptions what should be value to the field
mongocryptdSpawnPath in extraOptions for atlas cluster
if am doing wrong anything please correct me
Thank you
code:
const mongodb = require("mongodb");
const { ClientEncryption } = require("mongodb-client-encryption");
const { MongoClient, Binary } = mongodb;
const { join } = require('path');
require('dotenv').config();
// const { getCredentials } = require("./your_credentials");
// credentials = getCredentials();
var db = "medicalRecords";
var coll = "patients";
var namespace = `${db}.${coll}`;
// start-kmsproviders
const {readFileSync} = require("fs");
const provider = "local";
const path = join(__dirname,"./master-key.txt")
const localMasterKey = readFileSync(path);
console.log(localMasterKey)
const kmsProviders = {
local: {
key: localMasterKey,
// end-kmsproviders
const connectionString = process.env.URI;
// start-key-vault
const keyVaultNamespace = "encryption.__keyVault";
// end-key-vault
// start-schema
const schema = {
bsonType: "object",
encryptMetadata: {
// keyId: {
// $binary:{
// base64: "PadTrVggQL+MaHprhtzdcA==",
// subType: "04",
keyId: [ new Binary(Buffer.from("PadTrVggQL+MaHprhtzdcA==", "base64"),4)],
properties: {
insurance: {
bsonType: "object",
properties: {
policyNumber: {
encrypt: {
bsonType: "int",
algorithm: "AEAD_AES_256_CBC_HMAC_SHA_512-Random",
medicalRecords: {
encrypt: {
bsonType: "array",
bloodType: {
encrypt: {
bsonType: "string",
ssn: {
encrypt: {
bsonType: "int",
var patientSchema = {};
patientSchema[namespace] = schema;
// end-schema
// start-extra-options
const extraOptions = {
// mongocryptdSpawnPath: '.'
mongocryptdBypassSpawn: true,
// end-extra-options
// start-client -
const secureClient = new MongoClient(connectionString, {
useNewUrlParser: true,
useUnifiedTopology: true,
autoEncryption: {
keyVaultNamespace,
kmsProviders,
schemaMap: patientSchema,
extraOptions: extraOptions,
// end-client
const regularClient = new MongoClient(connectionString, {
async function main() {
console.log("inside main");
try {
//await regularClient.connect();
console.log('reg client')
try {
await secureClient.connect();
console.log('sec client')
// start-insert
try {
const writeResult = await secureClient
.db(db)
.collection(coll)
.insertOne({
ssn: 241014209,
bloodType: "AB+",
"key-id": "demo-data-key",
medicalRecords: [{ weight: 180, bloodPressure: "120/80" }],
insurance: {
policyNumber: 123142,
provider: "MaestCare",
} catch (writeError) {
console.error("writeError occurred:", writeError);
// end-insert
// start-find
console.log("Finding a document with regular (non-encrypted) client.");
console.log(
await regularClient.db(db).collection(coll).findOne({ name: /Jon/ })
console.log(
"Finding a document with encrypted client, searching on an encrypted field"
console.log(
await secureClient.db(db).collection(coll).findOne({ name: /Jon/ })
// end-find
} catch(err) {
console.log("secure",err);
finally {
await secureClient.close();
} finally {
await regularClient.close();
main();
Error:
MongoServerSelectionError: connect ECONNREFUSED 127.0.0.1:27020
at Timeout._onTimeout (D:\Node js\MongoDB_encryption\node_modules\mongodb\lib\sdam\topology.js:277:38)
at listOnTimeout (internal/timers.js:557:17)
at processTimers (internal/timers.js:500:7) {
reason: TopologyDescription {
type: 'Unknown',
servers: Map(1) { 'localhost:27020' => [ServerDescription] },
stale: false,
compatible: true,
heartbeatFrequencyMS: 10000,
localThresholdMS: 15,
setName: null,
maxElectionId: null,
maxSetVersion: null,
commonWireVersion: 0,
code: undefined,
[Symbol(errorLabels)]: Set(0) {}
