Compound multikey index not used in sort and range query
I’m confused about why the explain output for the following includes a sort stage (assume blocking?) when the compound index appears to comply with the ESR rule. Could it be because of this in the documentation where it says the sort will be blocking (and not an index sort) unless:
No boundaries for any multikey-indexed field have the same path prefix as the sort pattern.
However, I’m confused on the meaning of the terms “path prefix” and “sort pattern” and how it fits into the below scenario if at all.
db.STUDENT.insertMany([{
  "_id": 1,
  "FIRST_NAME": "Aaron",
  "PHONE": [
    {"PHONE_NUMBER": 1234, "PHONE_ID": 11 },
    {"PHONE_NUMBER": 2345, "PHONE_ID": 12, }
  "_id": 2,
  "PHONE": [
    {"PHONE_NUMBER": 3456, "PHONE_ID": 13 },
    {"PHONE_NUMBER": 4567, "PHONE_ID": 14, }
db.STUDENT.createIndex( { "FIRST_NAME": 1, "PHONE.PHONE_ID" : 1, "PHONE.PHONE_NUMBER": 1} )
and the query:
db.STUDENT.find({
    "$and": [{ "FIRST_NAME": "Aaron" }, {
        "PHONE": {
            "$elemMatch": {
                "$and": [{
                    "PHONE_NUMBER": {
                        "$gte": 3456
                    "PHONE_NUMBER": {
                        "$lte": 4567
}).sort({ "PHONE.PHONE_ID": -1 })
    .hint("FIRST_NAME_1_PHONE.PHONE_ID_1_PHONE.PHONE_NUMBER_1").explain(true)["executionStats"]
Result:
  executionSuccess: true,
  nReturned: 1,
  executionTimeMillis: 0,
  totalKeysExamined: 4,
  totalDocsExamined: 1,
  executionStages: {
    stage: 'SORT',
    nReturned: 1,
    executionTimeMillisEstimate: 0,
    works: 7,
    advanced: 1,
    needTime: 5,
    needYield: 0,
    saveState: 0,
    restoreState: 0,
    isEOF: 1,
    sortPattern: { 'PHONE.PHONE_ID': -1 },
    memLimit: 104857600,
    type: 'simple',
    totalDataSizeSorted: 160,
    usedDisk: false,
    inputStage: {
      stage: 'FETCH',
      filter: {
        PHONE: {
          '$elemMatch': {
            '$and': [
              { PHONE_NUMBER: { '$lte': 4567 } },
              { PHONE_NUMBER: { '$gte': 3456 } }
      nReturned: 1,
      works: 5,
      advanced: 1,
      needTime: 3,
      needYield: 0,
      saveState: 0,
      restoreState: 0,
      isEOF: 1,
      docsExamined: 1,
      alreadyHasObj: 0,
      inputStage: {
        stage: 'IXSCAN',
        nReturned: 1,
        works: 5,
        advanced: 1,
        needTime: 3,
        needYield: 0,
        saveState: 0,
        restoreState: 0,
        isEOF: 1,
        keyPattern: { FIRST_NAME: 1, 'PHONE.PHONE_ID': 1, 'PHONE.PHONE_NUMBER': 1 },
        indexName: 'FIRST_NAME_1_PHONE.PHONE_ID_1_PHONE.PHONE_NUMBER_1',
        isMultiKey: true,
        multiKeyPaths: {
          FIRST_NAME: [],
          'PHONE.PHONE_ID': [ 'PHONE' ],
          'PHONE.PHONE_NUMBER': [ 'PHONE' ]
        isUnique: false,
        isSparse: false,
        isPartial: false,
        indexVersion: 2,
        direction: 'forward',
        indexBounds: {
          FIRST_NAME: [ '["Aaron", "Aaron"]' ],
          'PHONE.PHONE_ID': [ '[MinKey, MaxKey]' ],
          'PHONE.PHONE_NUMBER': [ '[3456, 4567]' ]
        keysExamined: 4,
        seeks: 3,
        dupsTested: 2,
        dupsDropped: 1
  allPlansExecution: []
Jolix71, did you find your own answer to this? I’m about to post a similar question where I’m not sure why a compound index is not being utilized. In my research, I can across the recommendation that a sort field should be at the end of a compound index, but haven’t found that to be effective in my test case that I’m confused on.
