Hello,
Please, I need your help.
It has been a week since I got this issue of MongoSocketWriteException every time I try to connect to my Mongo DB from Postman or from my Android application. For info, I’m using heroku as the deployement solution infra and it has its own ssl certificate. I already added the adress IP in Atlas DB space.
2024-08-26T14:34:59.613712+00:00 app[web.1]: 2024-08-26 14:34:59.613 [cluster-ClusterId{value='66cc92902f17917f89ba00e6', description='null’}-myProjectCluster-shard-00-01.ht4av.mongodb.net:27017] TRACE org.mongodb.driver.cluster - Handling description changed event for server myProjectCluster-shard-00-01.ht4av.mongodb.net:27017 with description ServerDescription{address=myProjectCluster-shard-00-01.ht4av.mongodb.net:27017, type=UNKNOWN, state=CONNECTING, exception={com.mongodb.MongoSocketWriteException: Exception sending message}, caused by {javax.net.ssl.SSLException: Received fatal alert: internal_error}}
2024-08-26T14:34:59.613764+00:00 app[web.1]: 2024-08-26 14:34:59.613 [cluster-ClusterId{value='66cc92902f17917f89ba00e6', description='null'}-myProjectCluster-shard-00-01.ht4av.mongodb.net:27017] DEBUG org.mongodb.driver.cluster - Updating cluster description to {type=REPLICA_SET, servers=[{address=myProjectCluster-shard-00-01.ht4av.mongodb.net:27017, type=UNKNOWN, state=CONNECTING, exception={com.mongodb.MongoSocketWriteException: Exception sending message}, caused by {javax.net.ssl.SSLException: Received fatal alert: internal_error}}, {address=myProjectCluster-shard-00-00.ht4av.mongodb.net:27017, type=UNKNOWN, state=CONNECTING, exception={com.mongodb.MongoSocketWriteException: Exception sending message}, caused by {javax.net.ssl.SSLException: Received fatal alert: internal_error}}, {address=myProjectCluster-shard-00-02.ht4av.mongodb.net:27017, type=UNKNOWN, state=CONNECTING, exception={com.mongodb.MongoSocketWriteException: Exception sending message}, caused by {javax.net.ssl.SSLException: Received fatal alert: internal_error}}]
