I have a question about setting the connection pool and timeout.
Is there a way to calculate and set the optimal value?
Hi @rinjyu_N_A
This may be able to help you: Tuning Your Connection Pool Settings
The optimal values for those settings would be dependent on your use case and you specific deployment situation, so unfortunately there is no single easy answer for this.
However, are you seeing some error/issue that you think can be fixed by tuning those settings? Are the defaults not working out for you?
Best regards
Kevin
Hello.
I need to set the connection pool and timeout, but I wanted to get know-how because I didn’t have enough experience.
I will refer to the link you sent me.
Thanks for your help.
