Hi everyone,
First off - Kudos to the Realm team for building a great product. I am having a CORS issue when working with the GraphQL endpoint from the browser and hoping someone can lead me in the right direction. My issue is this: (apologies for the somewhat long explanation but I wanted to be as detailed as I could)
I am using a custom JWT Authentication solution, so I currently maintain all tokens for identity etc already in my app. I am able to setup a Custom JWT Authentication Authentication provider and input the corresponding JWK URI successfully in the Realm dashboard. It works fine after testing.
The problem I have is then trying to pass in the JWT in the header of the post request to Realm GraphQL endpoint https://realm.mongodb.com/api/client/v2.0/app//graphql from the browser using fetch. When I do so I get the below CORS error:
Access to fetch at âhttps://realm.mongodb.com/api/client/v2.0/app//graphqlâ from origin âhttp://localhost:3000â has been blocked by CORS policy: Response to preflight request doesnât pass access control check: No âAccess-Control-Allow-Originâ header is present on the requested resource. If an opaque response serves your needs, set the requestâs mode to âno-corsâ to fetch the resource with CORS disabled.
Please note that I am not currently using the realm-web package as I do not want to add an additional JWT token layer (realm-web maintains their own JWT token system in local storage) to my app that already has its own. I simply want to include the JWT token in the header of a fetch request to then have Realm verify against the JWK URI setup in the Realm dashboard. The docs here Authenticate GraphQL Requests make it seem like this is entirely possible as it notes that you can pass the custom JWT trough as a jwtTokenString
header using a normal http request. However, I still get the CORS error when attempting this request.
I have also tried whitelisting my http://localhost:3000 in the Realm dashboard under Manage > Settings > Allowed Request Origins. Still not able to get it to work.
I was able to get several less than ideal workarounds working:
Using another server as a proxy - since a node.js environment doesnât have these CORS restrictions I was able to pass the token through to another endpoint which fetched the Realm GraphQL endpoint from a server environment successfully. (Not great as that essentially creates 2 servers)
I was able to use both the realm-web package and my own system to make a more complicated auth system in which the realm-web package gave me a Bearer token to use without any CORS issues. (Not ideal as that requires 2 token systems)
Potential Solutions:
Iâm not positive on why the error is happening but I believe it may have something to do with the following that someone on the Realm team would have more context on:
Are the URLS whitelisted in Allowed Request Origins mapped to the approved URLS for CORS requests?
Is the Access-Control-Allow-Headers option on the wherever the Realm server is hosted allowing a header of jwtTokenString
Really appreciate anyone who can help lead me in the right direction on this.
Thank you!
