Hi All,
I am new to MongoDB. What I do I follow the installation guide to install MongoDB
Using tarball. My OS is Oracle Linux 8.4
After completed installation
I started
mongod --dbpath /var/lib/mongo --logpath /var/log/mongodb/mongod.log
and always got “illegal instruction (core dumped)”
I dont know how to check it, and there is no log too and not sure why coredump.
Can you advise where to check and how to fix it?
Appreciated . Thanks
May be it is a permissions issue
mongodb is unable to access dbpath & logpath directories
Does the owner of mongod have read/write privs on these dirs
For test purpse you can change db & log path to some other dir like your home dir and check
Stennie_X
(Stennie)
August 21, 2021, 9:28am
3
Welcome to the MongoDB Community Forums @Dinh_Hoang !
An illegal instruction error suggests that you are running a binary which is not supported by your CPU.
Can you confirm:
Your CPU details
Version of MongoDB server you have installed
Stennie
Thanks for reply.
I change dir again and start it but it is still the same
[mongod@localhost ~]$ ls -lrt
total 0
drwxrwxr-x. 2 mongod mongod 6 Aug 21 09:03 mongo
drwxrwxr-x. 3 mongod mongod 21 Aug 21 09:03 log
[mongod@localhost ~]$ ls -lrt /home/mongod/log/mongodb/
total 0
[mongod@localhost ~]$ ls -lrt /home/mongod/mongo
total 0
[mongod@localhost ~]$ mongod --dbpath /home/mongod/mongo --logpath /home/mongod/log/mongodb/mongod.log
Illegal instruction (core dumped)
I am using Oracle Linux 8.4 on Virtual Box, It is x86-64 bits
I downloaded Linux redhat/CentOS 8.0. Is it correct bin?
Thanks for your help
Just add in more detail for OS
Static hostname: localhost.localdomain
Icon name: computer-vm
Chassis: vm
Machine ID: ff3df1686a26409199f9686b0646ca6a
Boot ID: 88496d361dad421e9d1e11113f9559f6
Virtualization: oracle
Operating System: Oracle Linux Server 8.4
CPE OS Name: cpe:/o:oracle:linux:8:4:server
Kernel: Linux 5.4.17-2102.201.3.el8uek.x86_64
Architecture: x86-64
Hi All,
I downloaded 4.4 and it works, I am not sure why latest version 5.0.2 did not work for Oracle Linux 8.4
Have a nice day!
chris
(Chris Dellaway)
August 21, 2021, 8:09pm
7
Hi @Dinh_Hoang ,
This is likely related to changes in 5.0.
cat /proc/cpuinfo
has many of the details to look this up.
Stennie_X
(Stennie)
August 22, 2021, 12:48am
8
Hi @Dinh_Hoang ,
Can you provide the output of /proc/cpuinfo
as @chris suggested?
The likely reason for encountering an illegal instruction is that your CPU does not meet the x86_64 microarchitecture requirements for MongoDB 5.0.
Stennie
Hi Chris and Stennie,
Here is my info
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 142
model name : Intel(R) Core(TM) i5-8350U CPU @ 1.70GHz
stepping : 10
microcode : 0xffffffff
cpu MHz : 1895.999
cache size : 6144 KB
physical id : 0
siblings : 4
core id : 0
cpu cores : 4
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx rdtscp lm constant_tsc rep_good nopl xtopology nonstop_tsc cpuid tsc_known_freq pni ssse3 cx16 pcid sse4_1 sse4_2 hypervisor lahf_lm invpcid_single pti fsgsbase invpcid md_clear flush_l1d arch_capabilities
bugs : cpu_meltdown spectre_v1 spectre_v2 spec_store_bypass l1tf mds swapgs itlb_multihit
bogomips : 3791.99
clflush size : 64
cache_alignment : 64
address sizes : 39 bits physical, 48 bits virtual
power management:
There is 4 cores , So it should be a “Sandy Bridge* or later Core processor”
therefore I am confusing why It did not work for MongoDB 5
Dinh_Hoang
(Dinh Hoang)
August 22, 2021, 1:45pm
10
I found the note
MongoDB only supports Oracle Linux running the Red Hat Compatible Kernel (RHCK). MongoDB does not support the Unbreakable Enterprise Kernel (UEK).
It could be I am using kernel UEK, but how to check and confirm it?
Dinh_Hoang
(Dinh Hoang)
August 22, 2021, 1:53pm
11
#uname -a
Linux localhost.localdomain 5.4.17-2102.201.3.el8uek.x86_64 #2 SMP Fri Apr 23 09:05:57 PDT 2021 x86_64 x86_64 x86_64 GNU/Linux
It is EUK kernel but it works for 4.4 not 5.0.2, It is strange
Stennie_X
(Stennie)
August 22, 2021, 2:29pm
12
Hi @Dinh_Hoang ,
Your Core i5-8350U CPU looks like it should have the right feature support, but your /proc/cpuinfo
output is missing AVX extensions .
Can you confirm:
version of VirtualBox used
host O/S
It looks like there are a few conditions for AVX support in VirtualBox:
Stennie
Dinh_Hoang
(Dinh Hoang)
August 23, 2021, 12:44pm
13
Hi Stennie,
My Virtual box version is 6.1.26 (latest version) and on Win10 OS.
I tried 5.0.2 on Red hat OS 7.8, it works perfectly. Therefore it could be something with Oracle Linux kernel
Dinh
