I’ve been trying to get my Docker setup of MongoDB to work the whole day. Unfortunately, I was not able to.
I have a docker-compose.yml file in which I have my application and MongoDB:
services:
app:
build: ./app
restart: unless-stopped
env_file: "app/.env"
ports:
- 21865:21865
depends_on:
mongo:
condition: service_healthy
networks:
- mongo-network
mongo:
image: mongo:latest
ports:
- 27017:27017
env_file: "mongo/.env"
healthcheck:
test: ["CMD", "mongosh", "--eval", "db.adminCommand('ping')"]
interval: 10s
timeout: 10s
retries: 5
volumes:
- ./mongo/data:/data/db
- ./mongo/scripts:/docker-entrypoint-initdb.d/
networks:
- mongo-network
networks:
mongo-network:
driver: bridge
My entrypoint script is mongo/scripts/init.js:
use db1;
db.col1.insertOne({"exists": true});
db.createUser({
user: "<user>",
pwd: "<pw>",
roles: [ { role: "readWrite", db: "db1" } ]
use db2;
db.col2.insertOne({"exists": true});
db.createUser({
user: "<user>",
pwd: "<pw>",
roles: [ { role: "readWrite", db: "db2" } ]
I am using some probably redundant code to ENSURE the existence of the databases db1 and db2. However, when I launch Docker Compose and authenticate with root (docker-compose exec -it mongo mongosh -u "root" -p
) and run show databases
, the databases db1 and db22 are not shown:
test> show databases;
admin 100.00 KiB
config 12.00 KiB
local 72.00 KiB
Additionally, authentication, be it with or without specifying authSource, always fails. This is the output after my application attempts to authenticate.
docker-compose logs mongo | grep <user>
docker-server-mongo-1 | {"t":{"$date":"2024-10-20T17:31:28.573+00:00"},"s":"I", "c":"ACCESS", "id":20251, "ctx":"conn300","msg":"Supported SASL mechanisms requested for unknown user","attr":{"user":{"user":"<user>","db":"<db1>"}}}
docker-server-mongo-1 | {"t":{"$date":"2024-10-20T17:31:28.573+00:00"},"s":"I", "c":"ACCESS", "id":5286307, "ctx":"conn300","msg":"Failed to authenticate","attr":{"client":"192.168.160.3:44922","isSpeculative":true,"isClusterMember":false,"mechanism":"SCRAM-SHA-256","user":"<user>","db":"<db1>","error":"UserNotFound: Could not find user \"<user1>\" for db \"<db1>\"","result":11,"metrics":{"conversation_duration":{"micros":177,"summary":{"0":{"step":1,"step_total":2,"duration_micros":150}}}},"extraInfo":{}}}
docker-server-mongo-1 | {"t":{"$date":"2024-10-20T17:31:28.575+00:00"},"s":"I", "c":"ACCESS", "id":5286307, "ctx":"conn300","msg":"Failed to authenticate","attr":{"client":"192.168.160.3:44922","isSpeculative":false,"isClusterMember":false,"mechanism":"SCRAM-SHA-1","user":"<user>","db":"<db1>","error":"UserNotFound: Could not find user \"<user>\" for db \"<db1>\"","result":11,"metrics":{"conversation_duration":{"micros":194,"summary":{"0":{"step":1,"step_total":2,"duration_micros":181}}}},"extraInfo":{}}}
I was able to confirm that the MongoDB server is locally accessible by running curl:
> curl localhost:27017
It looks like you are trying to access MongoDB over HTTP on the native driver port.
Bash-ing into my application, curl also shows that the database is accessible:
> docker-compose exec -it app bash
bash-5.2# curl mongo:27017
I hope I have provided enough detail. I redacted the actual usernames, passwords and database names. Please assist me in resolving this The only solution I currently see is to authenticate my app with the root user, which I do not want to do.
