Having a problem when trying to connect to replica set with compass and with python code
Hi guys, I’m having a problem when trying to connect to replica set. I’m trying to connect with compass and with python code, but nothing happens.
My docker-compose file:
version: "3.9"
services:
  database:
    image : 'mongo'
    container_name: 'deibadb-container'
    environment:
      -  PUID=1000
      -  PGID=1000
    volumes:
      -  ./database:/data/db
    entrypoint: [ "/usr/bin/mongod", "--bind_ip_all", "--replSet", "rs0" ]
    ports:
      -  27017:27017
    restart: unless-stopped
  mongo-express:
    image: mongo-express:0.54
    ports:
      - "8081:8081"
    environment:
      ME_CONFIG_MONGODB_SERVER: database
    depends_on:
      - database
  typesense:
    image: typesense/typesense:0.21.0
    ports:
      - "8108:8108"
    environment:
      TYPESENSE_API_KEY: verbetes0key
      TYPESENSE_DATA_DIR: /data/typesense
      TYPESENSE_ENABLE_CORS: "true"
    volumes:
      - ./typesense:/data/typesense
My rs.status():
	"set" : "rs0",
	"date" : ISODate("2022-06-28T20:41:24.776Z"),
	"myState" : 1,
	"term" : NumberLong(1),
	"syncSourceHost" : "",
	"syncSourceId" : -1,
	"heartbeatIntervalMillis" : NumberLong(2000),
	"majorityVoteCount" : 1,
	"writeMajorityCount" : 1,
	"votingMembersCount" : 1,
	"writableVotingMembersCount" : 1,
	"optimes" : {
		"lastCommittedOpTime" : {
			"ts" : Timestamp(1656448876, 1),
			"t" : NumberLong(1)
		"lastCommittedWallTime" : ISODate("2022-06-28T20:41:16.041Z"),
		"readConcernMajorityOpTime" : {
			"t" : NumberLong(1)
		"appliedOpTime" : {
			"t" : NumberLong(1)
		"durableOpTime" : {
			"t" : NumberLong(1)
		"lastAppliedWallTime" : ISODate("2022-06-28T20:41:16.041Z"),
		"lastDurableWallTime" : ISODate("2022-06-28T20:41:16.041Z")
	"lastStableRecoveryTimestamp" : Timestamp(1656448828, 1),
	"electionCandidateMetrics" : {
		"lastElectionReason" : "electionTimeout",
		"lastElectionDate" : ISODate("2022-06-27T20:47:58.345Z"),
		"electionTerm" : NumberLong(1),
		"lastCommittedOpTimeAtElection" : {
			"ts" : Timestamp(1656362878, 1),
			"t" : NumberLong(-1)
		"lastSeenOpTimeAtElection" : {
		"numVotesNeeded" : 1,
		"priorityAtElection" : 1,
		"electionTimeoutMillis" : NumberLong(10000),
		"newTermStartDate" : ISODate("2022-06-27T20:47:58.368Z"),
		"wMajorityWriteAvailabilityDate" : ISODate("2022-06-27T20:47:58.379Z")
	"members" : [
			"_id" : 0,
			"name" : "70b5125bd4e1:27017",
			"health" : 1,
			"state" : 1,
			"stateStr" : "PRIMARY",
			"uptime" : 86088,
			"optime" : {
				"t" : NumberLong(1)
			"optimeDate" : ISODate("2022-06-28T20:41:16Z"),
			"lastDurableWallTime" : ISODate("2022-06-28T20:41:16.041Z"),
			"infoMessage" : "",
			"electionTime" : Timestamp(1656362878, 2),
			"electionDate" : ISODate("2022-06-27T20:47:58Z"),
			"configVersion" : 3,
			"configTerm" : 1,
			"self" : true,
			"lastHeartbeatMessage" : ""
	"ok" : 1,
	"$clusterTime" : {
		"clusterTime" : Timestamp(1656448876, 1),
		"signature" : {
			"hash" : BinData(0,"AAAAAAAAAAAAAAAAAAAAAAAAAAA="),
			"keyId" : NumberLong(0)
	"operationTime" : Timestamp(1656448876, 1)
When I trying from compass, a loading page still to trying connect. When trying from python code, I get:
pymongo.errors.ServerSelectionTimeoutError: Could not reach any servers in [(‘70b5125bd4e1’, 27017)]. Replica set is configured with internal hostnames or IPs?, Timeout: 30s, Topology Description: <TopologyDescription id: 62bc58af5e1aafde51de4af1, topology_type: ReplicaSetNoPrimary, servers: [<ServerDescription (‘70b5125bd4e1’, 27017) server_type: Unknown, rtt: None, error=AutoReconnect(‘70b5125bd4e1:27017: [Errno -3] Temporary failure in name resolution’)>]>
Could help me?
I get a solution to my issue. I followed this guide:
cfg = rs.conf()
cfg.members[0].host = “mongodb0.example.net:27017
rs.reconfig(cfg)
Available here
Basically was needed to update the host name of my replica set member.
