Hello everyone,
I am a junior developer and just starting out so please bare with me.
I am working on an app using Maven and even though I managed to have a database locally using JDBC, I can’t connect to my mongo database online.
This is my code
package xxxxxxxxxx.dao.dbutil;
import java.sql.Connection;
import java.sql.DriverManager;
import java.sql.SQLException;
import java.util.logging.Level;
public class DBUtil {
private static Connection conn;
private DBUtil() {}
private static final String URL = "jdbc:mongodb://cluster0.ktad2.mongodb.net:27017/test?ssl=true&authSource=admin";
public static Connection openConnection() throws SQLException {
java.util.Properties p = new java.util.Properties();
p.setProperty("user", "xxxxxxx");
p.setProperty("password", "xxxxxxxxxxxx");
p.setProperty("database", "test");
p.setProperty("loglevel", Level.SEVERE.getName());
//Registers JDBC Driver
try {
Class.forName("com.mongodb.jdbc.MongoDriver");
} catch (ClassNotFoundException e) {
System.out.println("ERROR: Unable to load SQLServer JDBC Driver");
e.printStackTrace();
System.out.println("MongoDB JDBC Driver has been registered...");
//Connects to mongodb database
System.out.println("Trying to get a connection to the database...");
try {
Connection conn = DriverManager.getConnection(URL, p);
} catch (SQLException e) {
System.out.println("ERROR: Unable to establish a connection with the database!");
return conn;
I have tried everything I can think of and still getting a timeout error
as well as
at gr.aueb.cf.teachersapp.controller.SearchTeacherController.doGet(SearchTeacherController.java:39)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:655)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:764)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:227)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:162)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:189)
at gr.aueb.cf.teachersapp.controller.GRFilter.doFilter(GRFilter.java:25)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:197)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:97)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:541)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:135)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:92)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:687)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:78)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:360)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:399)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:890)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1743)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at org.apache.tomcat.util.threads.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1191)
at org.apache.tomcat.util.threads.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:659)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.base/java.lang.Thread.run(Thread.java:829)
[2022-10-25 22:54:41.809] [SEVERE] [c-2] com.mongodb.jdbc.MongoConnection: Error in MongoConnection.testConnection(..)
java.util.concurrent.TimeoutException
at java.base/java.util.concurrent.FutureTask.get(FutureTask.java:204)
at com.mongodb.jdbc.MongoConnection.testConnection(MongoConnection.java:480)
at com.mongodb.jdbc.MongoDriver.connect(MongoDriver.java:169)
at java.sql/java.sql.DriverManager.getConnection(DriverManager.java:677)
at java.sql/java.sql.DriverManager.getConnection(DriverManager.java:189)
at gr.aueb.cf.teachersapp.dao.dbutil.DBUtil.openConnection(DBUtil.java:35)
at gr.aueb.cf.teachersapp.dao.TeacherDAOImpl.getTeachersByLastnane(TeacherDAOImpl.java:110)
at gr.aueb.cf.teachersapp.service.TeacherServiceImpl.getTeacherByLastname(TeacherServiceImpl.java:86)
java.sql.SQLTimeoutException: Timeout. Can't connect.
at com.mongodb.jdbc.MongoDriver.connect(MongoDriver.java:171)
[2022-10-25 22:54:41.809] [SEVERE] [c-2] [stmt-1] com.mongodb.jdbc.MongoSQLStatement: Error in MongoSQLStatement.executeQuery(..)
com.mongodb.MongoInterruptedException: Interrupted while waiting to connect
at com.mongodb.internal.connection.BaseCluster.getDescription(BaseCluster.java:211)
at com.mongodb.internal.connection.SingleServerCluster.getDescription(SingleServerCluster.java:41)
at com.mongodb.client.internal.MongoClientDelegate.getConnectedClusterDescription(MongoClientDelegate.java:155)
at com.mongodb.client.internal.MongoClientDelegate.createClientSession(MongoClientDelegate.java:105)
at com.mongodb.client.internal.MongoClientDelegate$DelegateOperationExecutor.getClientSession(MongoClientDelegate.java:287)
at com.mongodb.client.internal.MongoClientDelegate$DelegateOperationExecutor.execute(MongoClientDelegate.java:191)
at com.mongodb.client.internal.MongoDatabaseImpl.executeCommand(MongoDatabaseImpl.java:194)
at com.mongodb.client.internal.MongoDatabaseImpl.runCommand(MongoDatabaseImpl.java:163)
at com.mongodb.client.internal.MongoDatabaseImpl.runCommand(MongoDatabaseImpl.java:158)
at com.mongodb.jdbc.MongoSQLStatement.executeQuery(MongoSQLStatement.java:60)
at com.mongodb.jdbc.MongoStatement.execute(MongoStatement.java:175)
at com.mongodb.jdbc.MongoConnection$ConnValidation.call(MongoConnection.java:448)
at com.mongodb.jdbc.MongoConnection$ConnValidation.call(MongoConnection.java:1)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
Caused by: java.lang.InterruptedException
at java.base/java.util.concurrent.locks.AbstractQueuedSynchronizer.doAcquireSharedNanos(AbstractQueuedSynchronizer.java:1081)
at java.base/java.util.concurrent.locks.AbstractQueuedSynchronizer.tryAcquireSharedNanos(AbstractQueuedSynchronizer.java:1369)
at java.base/java.util.concurrent.CountDownLatch.await(CountDownLatch.java:278)
any help would be greatly appreciated!!
