I am using MongoDB version 6.0.
I have a MongoDB document structured as follows:
"_id": "123456",
"info": {
"area_name": "foo",
"type_name": "bar",
"year": 2024
// other fields
"state": 1
// other fields
The info field is a nested document, and I’ve omitted several fields in the example structure above.
I want to use change streams to monitor updates to all fields within the info nested document, while ignoring changes to other fields such as state. How can I achieve this?
I am developing with Java and Spring Data MongoDB.
Here are my attempts so far:
final var options = ChangeStreamOptions.builder()
.fullDocumentBeforeChangeLookup(FullDocumentBeforeChange.REQUIRED)
.filter(Aggregation.newAggregation(
Aggregation.match(
where("updateDescription.updatedFields.info").exists(true)
.build();
reactiveMongoTemplate.changeStream("collection_name", options, Foo.class)
.subscribe(this::doSomething);
For example, I modified the info.year field, but it didn’t seem to work.
The reason appears to be that the value of the updatedFields field in ChangeStreamEvent is info.year instead of info, so the filter condition I added in ChangeStreamOptions didn’t work.
