The result of number 7 is:
● mongod.service - MongoDB Database Server
Loaded: loaded (/lib/systemd/system/mongod.service; enabled; vendor preset: enabled)
Active: failed (Result: core-dump) since Thu 2021-08-05 20:33:13 MDT; 39s ago
Docs:
Process: 10094 ExecStart=/usr/bin/mongod --config /etc/mongod.conf (code=dumped, signal=ILL)
Main PID: 10094 (code=dumped, signal=ILL)
Aug 05 20:33:13 Lanny systemd[1]: Started MongoDB Database Server.
Aug 05 20:33:13 Lanny systemd[1]: mongod.service: Main process exited, code=dumped, status=4/ILL
Aug 05 20:33:13 Lanny systemd[1]: mongod.service: Failed with result ‘core-dump’.
How to I correct this problem? Ideally, I’d like to install the latest version of MongoDB to my home directory without using the apt, but installing via a downloaded file.
It appears I am running Nehalem microarchitecture (1st generation) Intel(R) Core™ i5 CPU 750 @ 2.67GHz on Ubuntu 18.04, so my CPU is too old for the current Mongo 5.0 distribution.
Since there is a way to compile the Mongo 5.0 source to work on the Nehalem microarchitecture, can you please compile one for me so I may install that??
There are many of us who have older CPU’s that don’t relish being denied the latest Mongo 5.0 version.
Your Nehalem CPU is unfortunately a generation older than what we currently test & support for MongoDB 5.0. Prebuilt binaries are not available and this build combination is no longer part of our testing matrix.
Your options are:
Build from source yourself (or get a trusted binary from someone else who builds on your behalf). This CPU microarchitecture is still not tested or supported for MongoDB 5.0+ if you run into unexpected behaviour or issues.
Use the last supported release series for your microarchitecture, which is MongoDB 4.4.
Use MongoDB 5.0 via a remote server instance or managed database service.
