Is it possible a solution for a very slow query with aggregation?
Hi :wave:, I’m working on a query that works fine and does what I want but it’s too slow (1.5s-2s) and I don’t know why. Could you help me understand the reason for this slowness and a possible solution.
I have a collection where each document is like this:
     _id:
     date: Date
     technicalOne:   ObjectId
     client:   ObjectId
     center:   String
     appointments: [
          isBlockTime:   boolean
          isRecurrentBreak:   boolean
          isOcasionalMeet:   boolean
          isRemoteWork:   boolean
          isOcasionalRemote:   boolean
          isOcasionalClientRemote:   boolean
          busyDays:   Array of numbers
          busyDaysWithout:   Array of numbers
          state:    number
          _id:
          isTechnicalOne:   boolean
          technical:    String
          technicalId:   ObjectId
          date:    Date
And de pipleline is this:
const pipeline = [
            '$unwind': {
                'path': '$appointments',
                'preserveNullAndEmptyArrays': false
            '$match': {
                'appointments.technical': technicalSelected,
                'center': workCenter,
                'appointments.state': 0,
                'appointments.date': {
                    '$gte': moment(startDate).startOf('month').toDate(),
                    '$lte': moment(endDate).endOf('month').toDate()
            '$sort': {
                'appointments.date': 1,
                'appointments.busyDays': 1
            '$lookup': {
                'from': 'clienthistories',
                'localField': 'client',
                'foreignField': '_id',
                'as': 'client'
            '$unwind': {
                'path': '$client',
                'preserveNullAndEmptyArrays': true
            '$lookup': {
                'from': 'users',
                'localField': 'appointments.technicalSave',
                'as': 'user'
            '$unwind': {
                'path': '$user',
            '$project': {
                'center': '$center',
                'technical': '$technical.technical',
                'savedFor': '$user.technical',
                'date': '$appointments.date',
                'dateTakeAppointment': '$dateTakeAppointment',
                'busyDays': '$appointments.busyDays',
                'client': '$client',
                'appointment': '$appointments',
                'busyDaysWithout': '$appointments.busyDaysWithout',
                'appointmentObservation': '$appointmentObservation',
            '$sort': {
                'busyDays': 1
    const AppointmentsCollection = Appointments.collection
    const appointments = await AppointmentsCollection.aggregate(pipeline).toArray()
The maxium results are 120-180 documents.
What is wrong with this query?
Thank you very much :blush: :blush: :blush: :blush:
  1. Make sure you have an index on the fields you use in $match
  2. You should $match before $unwind:$appointments
  3. Since you terminate with $sort:{busyDays:1}, I am pretty sure the first $sort is useless.
  4. You should do $unwind:$clients after $lookup:{from:users}. Doing it before increases the work that has to be done in $lookup because you have more documents.
  5. In you $project, you already do appointment:$appointements so all other fields from appointments like busyDays are useless and just send more duplicated data over the network.
Thank you very much! the query now is faster than before. :slight_smile:
