Greetings to all,
I have some issues with configuration of MongoDB replicaSet within a Swarm Cluster. Here is my docker-compose file:
version: "3.8"
x-node-env: &node-env
MONGO_INITDB_ROOT_USERNAME: ${DATABASE_USER}
MONGO_INITDB_ROOT_PASSWORD: ${DATABASE_PASSWORD}
services:
mongo1:
image: mongo:4.4
networks:
net:
aliases:
- mongo1
command: bash -c "
chmod 400 /var/local/company/keys/mongodb_openssl.key &&
mongod --config /data/config/cluster.conf
environment:
<<: *node-env
volumes:
- "${DATABASE_PATH}:/data/db:rw"
- "${KEYFILE_DIR}:/var/local/company/keys:r"
- "${CONFIG_DIR}:/data/config:r"
deploy:
placement:
constraints: [node.hostname == swarm-master1]
mode: 'replicated'
replicas: 1
ports:
- 27051:27017
mongo2:
image: mongo:4.4
networks:
net:
aliases:
- mongo2
command: bash -c "
environment:
<<: *node-env
volumes:
- "/tmp/db2:/data/db:rw"
deploy:
placement:
constraints: [node.hostname == swarm-node1]
mode: 'replicated'
replicas: 1
ports:
- 27052:27017
depends_on:
- mongo1
mongo3:
image: mongo:4.4
networks:
net:
aliases:
- mongo3
command: bash -c "
environment:
<<: *node-env
volumes:
- "/tmp/db3:/data/db:rw"
deploy:
placement:
constraints: [node.hostname == swarm-node2]
mode: 'replicated'
replicas: 1
ports:
- 27053:27017
depends_on:
- mongo1
networks:
net:
driver: overlay
My cluster.conf file is:
storage:
dbPath: /data/db
replication:
replSetName: test1
net:
port: 27017
bindIpAll: true
security:
keyFile: /var/local/company/keys/mongodb_openssl.key
So my primary problem(IMHO) is the connectivity. It looks like when I deal with the replicatSet the MONGO_INITDB_ROOT_USERNAME and MONGO_INITDB_ROOT_PASSWORD seem to be ignored. When I connect to the master container and then try to connect to the mongodb using user/password provided within env variable and I get rejected. I can connect mongo without passing user/password and initialize the replicaSet, but the issue remains the same, the cluster remains unusable due to missing credentials. For this example I’ve used admin/admin as credentials and what I can observe in the logs is:
{ "c":"ACCESS", "id":20249, "ctx":"conn1","msg":"Authentication failed","attr":{"mechanism":"SCRAM-SHA-256","speculative":true,"principalName":"admin","authenticationDatabase":"admin","remote":"127.0.0.1:45482","extraInfo":{},"error":"UserNotFound: Could not find user \"admin\" for db \"admin\""}
If I remove replicaSet config everything works like a charm, user/pass are created and one can connect to the each separate mongo instance.
Many thanks for your help.
