I am trying to setup a database trigger for an embedded object .
My Embedded Object is set up as :
"review_info" :{
"in_review" : boolean,
"date" : Date,
I am trying to run a database trigger, when a document is updated and in_review is set to true.
For that the query in my trigger configuration is set as ::
"updateDescription.updatedFields" : {
"review_info.in_review": true
So when I change the “review_info.in_review” manually from mongo data services (collections), the trigger is working fine, but if the same data is changed from client app (which is a flutter app with atlas device sync sdk (realm)), I am getting the error :
error in read messages loop: could not decode next message:
failed to get reader: WebSocket closed:
failed to acquire lock: context deadline exceeded
The funny thing is if i set up the query as :
"review_info": { "$exists" : true}
The trigger works fine.
