Mongo Atlas storage size and index size 50% bigger than expected compared to on premise
Greetings.
We are wondering why your dataset in Mongo Atlas is almost 40% bigger than the dataset that we have on premise.
I have exported the dataset from atlas using mongodump and imported with mongorestore in our on premise environment and the difference is huge.
I had run the scripts found in https://github.com/tap1r/mongodb-scripts/blob/master/DB%20Storage%20tools.md#storage-engine-usage-reporting in both environments
to get some information.
Description:
Images where taken from MongoDB Compass after compacting (using db.runCommand({ compact: collectionname})) the collections.
On premise machines are running latest AWS Linux version with XFS filesystem, blocksize 4k and Mongo 7.0.1
ATLAS CLUSTER
MONGO-ATLAS-DBSTAT-SCRIPT.txt (15.5 KB)
ON PREMISE
MONGO-ON-PREMISE-DBSTAT-SCRIPT.txt (9.8 KB)
