Followed below steps:
Create docker
docker run -d -p 27017:27017 --name=mongodb -v data-mongodb:/data/db mongo:latest -
docker ps --format “{{.ID}}: {{.Names}}”
2c9750587438: mongodb
5a2235c4d8ff: kafka1
787678268f91: zoo1
- docker exec works fine.
docker exec -it mongodb mongosh
Current Mongosh Log ID:
669d460e704e58c860149f47
Connecting to: mongodb://127.0.0.1:27017/?directConnection=true&serverSelectionTimeoutMS=2000&appName=mongosh+2.2.10
Using MongoDB: 7.0.12
Using Mongosh: 2.2.10
For mongosh info see: https://docs.mongodb.com/mongodb-shell/
The server generated these startup warnings when booting
2024-07-21T17:04:51.689+00:00: Using the XFS filesystem is strongly recommended with the WiredTiger storage engine. See http://dochub.mongodb.org/core/prodnotes-filesystem
2024-07-21T17:04:52.012+00:00: Access control is not enabled for the database. Read and write access to data and configuration is unrestricted
2024-07-21T17:04:52.013+00:00: Soft rlimits for open file descriptors too low
test>
- from pymongo
import MongoClient client = MongoClient('mongodb://127.0.0.1:27017/')
client.list_database_names()
GIVES timeout error.
raise ServerSelectionTimeoutError(
pymongo.errors.ServerSelectionTimeoutError: 127.0.0.1:27017: [Errno 104] Connection reset by peer (configured timeouts: socketTimeoutMS: 20000.0ms, connectTimeoutMS: 20000.0ms), Timeout: 30s, Topology Description: <TopologyDescription id: 669d447f24ef3e38dc949128, topology_type: Unknown, servers: [<ServerDescription ('127.0.0.1', 27017) server_type: Unknown, rtt: None, error=AutoReconnect('127.0.0.1:27017: [Errno 104] Connection reset by peer (configured timeouts: socketTimeoutMS: 20000.0ms, connectTimeoutMS: 20000.0ms)')>]>
Please help me resolve this issue.
