MongoError: unknown top level operator: $in. If you have a field name that starts with a ‘$’ symbol, consider using $getField or $setField.
at MessageStream.messageHandler (/app/node_modules/mongoose/node_modules/mongodb/lib/cmap/connection.js:299:20)
at MessageStream.emit (node:events:513:28)
at processIncomingData (/app/node_modules/mongoose/node_modules/mongodb/lib/cmap/message_stream.js:144:12)
at MessageStream._write (/app/node_modules/mongoose/node_modules/mongodb/lib/cmap/message_stream.js:42:5)
You’re likely trying to use the $in
operator directly without wrapping the operation correctly to perform either a find
or and aggregate
Can you share the code where you’ve specified an $in
I have function like this that returns the query:
function getMovieFilterQuery(filters = {}){
const query = {}
if (filters.moviesIds !== undefined) {
query.movieId = { $in: filters.movieIds };
return query;
@ramanjaneya_karnati you’ll likely need to trace the caller of getMovieFilterQuery
to see how the function result is being passed to a query, but given the error you shared you’re likely sending a command similar to the following to the server:
db.foo.find({ $in: [ 'movie1', 'movie2' ] })
The server is expecting you to send:
db.foo.find({ movieId: { $in: [ 'movie1', 'movie2' ] }})
Stepping through your logic should surface the issue pretty quickly.
