Problem with $merge using migrate-mongo
Hello, I have the problem with $merge stage similar to Cannot get $merge to work with node.js driver 3.5.9 in a 3rd party library, migrate-mongo.
I read the migrate-mongo source code in GitHub, migrate-mongo returns the db and then we can simply run await db.collection('collection-name').aggregate([/* stages */]). but this method can not create the new collection. here is the code:
await db.collection('admins').aggregate([
        $addFields: {
            adminId: '$_id',
        $project: {
            _id: 0,
            adminId: 1,
            username: 1,
            password: 1,
            lastname: 1,
            phoneNumber: '$info.phoneNumber',
            createdAt: 1,
            updatedAt: 1,
        $addFields: {
            isPhoneNumberVerified: true,
            role: 'ADMIN',
            gender: 'UNKNOWN',
        $merge: {
            into: 'users',
but this aggregate can not create the users collection. can you help me?
can you provide me your repo/source code, I wanna read it to figure it out how you deal with $merge stage in nodejs mongodb driver.
thanks regardless
Kasir barati
Resolved. If you face the same problem try this check list:
  1. check your mongodb-server version
  2. check if you put the .toArray()
  3. run your aggregate in mongo-compass
