I’m trying to build a docker image which I use during my rust integration tests.
For that I build a pipeline step in my gitlab ci/cd which builds the test image.
For that the DinD runner starts a docker compose container which mounts ./data:
volumes:
- ./mongo-init.js:/docker-entrypoint-initdb.d/mongo-init.js:ro
- ./data/db:/data/db
After that the Dockerfile which will be build, should copy the ./data/db directory to /data/db in the mongodb image. This should speed up the later docker setup during the rust tests a little bit (create shards and stuff). So the mongodb docker container don’t have to parse the mongo-init.js during the rust tests.
Here is the whole docker compose file which will be started. After some seconds it will be shutted down to create the data/db content:
services:
mongodb-test-image-builder:
image: mongo:latest
restart: unless-stopped
command: mongod --replSet rs0 --bind_ip 0.0.0.0
user: root
volumes:
Before I run docker compose up -d I run:
rm -fr ./data/
mkdir ./data
chmod -R 777 ./data/
chown -R 999:999 ./data/
But I get always the following server log while startup and no file will be created:
I’m very confused. Even if I enter the ci/cd runner docker image myself and then excecute everthing manually it does not work.
T
