Problems with MongoDB Atlas and AWS DMS
I have a problem that I really don’t know how to solve or what approach to take. For data analysis and other similar things I need to use the AWS data migration service to migrate data from mongoDB to an AWS Redshift, but when I run the migration task I always get an error: “Unable to find transaction: …” . This process reads the oplog of the replica set. I have seen that this problem only occurs in certain collections not in all but I can’t find the possible cause. Any ideas?
I have a developer having a similar issue where they’re trying to connect MongoDB Atlas to S3 via AWS DMS
They got this error:
Test Endpoint failed: Application-Status: 1020912, Application-Message: Failed to create new client connection Failed to connect to database., Application-Detailed-Message: Error verifying connection
But looking at the AWS documentation, looks like AWS doesn’t support MongoDB Atlas yet with AWS DMS? Or am I mistaken? What’s the best course of action here?
Hello mates,
I was able to perform cdc once. However, I’ve deleted my replication instance and now I’m currently not able to establish the database connection again.
Let me know in case you accomplish it, please.
Diego
Hi Chris,
At this moment I have some DMS task working fine with MongoDB Atlas, so I suppose you have another problem. I have a problem with some specific mongo collections but I can connect with Mongo Atlas.
In your case I would check the DMS connection config and the mongoDB Atlas security config
Hi Diego,
Do you have another mongoDb replicaset or you only have removed the replication instance?. DMS needs a mongo log with name “oplog”, this log is created when you have a mongodb replicaset, without this log I dont think DMS works
Juan
I had that issue before and ours was related to the url schema. DMS failed when trying to connect to the url mongodb+srv:// but worked when we connected to the analytics node mongodb://
Hi @Juan_Luis_Garcia
Did you found any solution for “Error reading the database log. Stop Reason FATAL_ERROR Error Level FATAL”. I am facing with same issue, When I am doing any add/edit/delete actions from compass DMS replication is working, but when we are add/edit/delete action from application replica is not happening. Only the difference is DMS connects with MongoDB:// and my application connects with MongoDB+srv:// .
We were facing the same problem. The issue seemed to be a bad implementation of reading from change_stream from AWS DMS side. AWS DMS is firing a full collection scan query for fetching every single oplog record and the oplog collection is not indexed in mongodb. Neither you can define an index manually. So, for fetching every change it was firing a query which was taking >5secs and scanning the complete local.rs.oplog collection. Initially, we had created a user for dms and we were running the DMS pipeline using the same but it was throwing this ‘Unable to find transaction error’. Then, when we configured it to run with admin user, the pipeline ran successfully but we had to drop DMS as solution because of this inefficient implementation.
