Hello, I have some questions regarding UpdateOne and InsertOne behavior when performed in the same unordered BulkWrite operation or separately in 2 BulkWrites but executed at the exact same time.
For example, if I perform the 2 operations below in a single unordered BulkWrite:
db.collection.insertOne(
"_id": "A",
"status": "in_progress",
db.collection.updateOne(
{ "_id": "A" },
"_id": "A",
"status": "success",
{ upsert: true }
I would assume that, after execution, the resulting document would always have a status of success. However, after load testing, I still find some documents with an in_progress status.
My questions are:
What is causing this behavior? Looking at the operation, I would assume that either the insert is performed first and would then be overridden by the update or the insert is performed second which would throw a duplicate key exception due to the unique index
_id. -
Is there any way to guarantee that the data in the UpdateOne would always be the one persisted in the resulting document?
I would appreciate any help. Thank you.
