I wanted to know if its possible to use Realm with redux on react-native?
Hi @Tony_Ngomana,
I don’t see a reason why not.
Have you checked our Realm react-native SDK:
Best regards,
Pavel
Yes i have the problem is i’m building a massive app and react context isn’t the right tool for the app. I opted to use redux. But when using it i stumbled upon an error when i tried to export useRealm
. I need to use useRealm
in a redux-thunk
function but however my app won’t compile because of an error caused by user
and partitionValue
my code below:
import Realm from "realm";
import { getRealmApp } from "../functions/realmConfig";
import { ItemSchema } from "./itemSchema";
const app = getRealmApp();
const user: any = Realm.User;
const useConfig = {
schema: [ItemSchema], //other schema will be added in the future
sync: {
user: user.apiKeys,
partitionValue: user.name,
export const useRealm = Realm.open({
sync: {
user: user.prototype,
partitionValue: app.currentUser?.id!,
Hello Tony,
I would highly recommend against putting realm collections and/or items in a redux store, as Realm objects are self-mutating objects, and therefor wont play well with the principles of redux.
That said, there are some issues with the code snippet you supplied:
Realm.User
is not a user instance, it’s the class
defining a realm-user.
You seem to never actually authenticate a user for sync.
Please see: https://docs.mongodb.com/realm/react-native/quick-start/#authenticate-a-user
So you’ll first need to determine how your users will authenticate? email/password, facebook etc?
When you have a logged in user instance, this can be used in the sync config (and not Realm.User.prototype
. If this is in our docs or examples somewhere, please let me know).
Theoretical example (this uses anonymous login):
const openSyncedRealm = async () => {
const user = await app.logIn(Realm.Credentials.anonymous());
const realm = await Realm.open({
sync: {
user,
partitionValue: user.id,
error: (e) => {
console.log(e);
return realm;
Thank you, guess i will have to look for alternatives
